Garden Bib Tap on a 10mm PEX Barrier pipe
2 Feb 2016
I have Hose Union Bib Tap I want to install on a garden wall. I'm going to be running PEX Barrier pipe. In order to run the pipe discretely the length of PEX pipe I will need to run will be approximately 13 meters. I have a 25m roll of 10mm PEX barrier pipe, The pipe I will be Tee'ing off will be the cold line from the washing machine supply. I havent checked what size pipe is supplying the washing machine but if it's anything like the rest of the house I assume it will also be 10mm PEX barrier. Question is: is it ok to run the bib tap on a 10mm barrier pipe across a 13 meter run?
It's OK, so long as you leave provision to drain it in winter, but you may not get much of a flow rate.
