Garden Building - Couple of general questions...
25 Jun 2004
Hi guys
Just looking for some general advice really as I am at the planning/preparation stage for building a free standing games room at the end of my garden.
From what I can tell, the best option is to use SIPs for the walls and ceiling. I definitely want good thermal properties and want to be able to heat the room efficiently/cheaply, plus avoid it getting too warm in summer. So my basic plan is to try and pick up some cheap double-glazed windows and patio doors on Gumtree, and build walls and ceiling in SIPs with some sort of cladding on the exterior and board out/skim inside. Hopefully all straightforward enough!
The main thing I am a little unsure of is the base. I suspect that a concrete base is going to be best? I am looking at a total size of approx. 10m x 6m so this is going to be quite a large pad. I just need a solid base because I want to have a snooker table! What I can't figure out is whether I need a wooden sub-floor above the level of the concrete? (assuming I do go with concrete base of course). I'm assuming I shouldn't just use the concrete base as the floor? ie latex and carpet tiles straight onto the concrete?
Sorry if this is a very daft question!! I am extremely grateful for any advice!
Building regs will apply so that will determine the construction options.
That's not SIP's.
Maybe he is on about the Tea
The rear and right hand sides were made that way. I just built a frame for the rest.
assuming its near a fence remember the need to keep it below 2.5m to avoid the need for planning permission
