I removed the garden door threshold (20mm mdf board, about 25cm wide and 190cm long) to see what's under it and here is what I found
I have a few questions.
Is that plastic thing a cavity closer?
The inner leaf of the house is built from blocks (aircrete), so why are there regular bricks here and not blocks?
Is it OK to put a layer of mortar over the cavity closer and bricks to get a flat surface? I would not go over the insulation (between the bricks and screed), just the bricks and closer.
