Garden Electrics
23 Nov 2005
Nr Colchester, Essex
I want to run electric to a summerhouse. Primarily I want to have lighting and perhaps be able to have a small convector heater for cool evenings.
The total run will be about 45 feet from the source. I'm assuming the best and safest way will be to lay armoured cable but I'd welcome any suggestions for an alternative. It will be laid across (under) my lawn.
I already have a Single Gang Outdoor Weatherproof Socket IP55 (it's not 100% weatherproof as the lid doesn't fully close with the plug inserted) in the garden on a power source from my workshop and I'm thinking of replacing that with a fully weatherproof junction box and connecting the cable to that and spuring off from that if I need sockets etc. in the garden for lights.
Would welcome advice on the correct type/size of cable I should use, also the best type of weatherproof junction box which I believe needs to be to to IP56 rating, although I've seen same rated IP55 and even IP44. Also advice on type of glands/connectors I should get.
