Hi Everyone,
I am landscaping my garden so have had diggers in etc. and so I am installing underground irrigation. I am using MDPE 20mm to connect direct from mains around garden to various soaker and micro irrigation systems.
I have some concerns though!
I have ordered dual check valves (20mm MDPE) but am not sure at what pressure they work?! Any ideas?!
I also am unable to find an appropriate pressure reduction valve that will fit the system and am now confused as to where to connect it before or after the no return valve? Need 20mm otherwise I need to buy a host of adaptors!
At present the plan was as follows:
From mains to on/off valve followed by timer. From timer to pressure reduction then to tpiece... one way to front garden, the other to back garden.
For the front, install the two way check valve then to drip irrigation system for hanging baskets etc.
For the back... to another t-piece one will be a tap for the BBQ / drinks area, used for rinsing glasses etc. (non-return tap!) The other to a soaker hose (around 40 metres worth!)
Question... Would I be better running the system high pressure until I reach the irtrigation system sections and then reduce the pressure?
Please help!!!!
Please help!!!!
