HI,
At 70 I'm trying to get to grips with this Internet thingymajig, so if I've written this in the wrong place or in some other way I've broken the rules, please accept my apologies; the fact that I'm able to write this at all is a triumph for me. Anyhow, down to business. Can anybody please help me?
I recently bought a used shredder off Gumtree. The details of which are: Performance Power, quiet shredder, 2500w, model: PSS500, I think it's a B&Q machine, but they appear not to make it any longer. When I bought it, it was working perfectly and for the past few days it worked faultlessly. However, when I came to adjust the pressure plate, something snapped and the machine stopped shredding and began to just break the sinews of the wood.
On inspection I discovered that the adjusting mechanism is not of a robust design. The housing in which it is held is cast metal and it was obvious that the strain of holding the pressure plate against the rotary blades had caused it to fail, taking out a piece of the cast metal. After some thought I recognised that I could make a repair that would not only be successful, but would be stronger that the original design.
After carefully taking the unit to pieces, marking and noting what wire went where, I cut and drilled a piece of metal to order. Then I drilled two holes through the cast on either side of the break and bolted my piece of metal, as a bridge across the broken piece of cast, securely pinning the damaged section in place.
Again, carefully, I reversed the dismantling process, I put all the screws in the right place; I reconnected all the wires correctly; bolted the whole unit down on its base, inserted the collecting bin, ensuring the safety pin was in place. I tried the repair and the pressure plate moved in against the blades and back as the knurled knob was turned. Success! I thought. But when I plugged it in nothing happened. I changed the fuse – to no avail. I took the unit apart again to check the wiring, everything was put back right as I had known it had been.
Can anybody offer any help please? I have never been afraid to tackle any mechanical objects, but I am no expert with electrics – therefore, I would welcome help in that area especially. I think it is necessary to point point out that the unit was working before I dismantled it.
I thank you in anticipation of your very welcome expertise.
