Hi
I want to build a timber framed garden office but our soil is clay. There is one sliver birch tree about 2m away. The size will be approximately 7x4m.
The quote I have been given is as follows:
The area will be excavated to 400m and all arisings carted away.
A timber form work will be placed around the edge. The outer edge will be left at 400mm x 400mm deep to create a "TOE". This adds strength at the weakest point, the perimeter. A sub-base of crushed type one will be spread across the remaining base to a depth of 200mm and compacted.
We will use a concrete pump lorry to pump the concrete delivery to the base. This will be in a continuous pour.
The concrete will be tamped and float finished. The concrete used will be fiberous.
The cost for this is ......£6400+VAT.
This seems a lot to me as my brother-in-law has just started his and admittedly he did the excavations himself but the cost of the reinforced concrete came to £1,000.
Any thoughts or recommendation for ground workers in the Chelmsford area.
Cheers
S
Cheers
S
