I've decided with the house occupied by children that I need my office to be in the garden. The first part of this project is to look at prefab solutions then cost up building my own. I'm currently pulling together a spreadsheet of items necessary to reach the spec required and have a couple of questions.
A friend has a spare roll of cromar vent free however I was planning on using tyvek on the walls and roof, is cromar a comparable product and can it be used instead of tyvek?
Insulation wise I'm allowing the following:
All celotex
Floor: 25mm
Walls: 75mm in cavity 25mm covering all everything internally
Ceiling: 50mm
Does this sound about right? I assume celotex whilst expensive is really the only way to go
For the roof I initially thought about insulated pressed steel but feel the following would be just as good, cheaper and perhaps easier to install:
Tyvek or cromar over roof joists, 18mm wpb over membrane. 50mm celotex over wpb then epdm over the lot.
Using the materials above I believe I could create a sound well insulated environment that's 4x3m for about £3.5k as apposed to a comparable pre fab solution for £12k
Any experience or tips much appreciated
All celotex
Floor: 25mm
Ceiling: 50mm
