Hello all
I'm currently designing a Garden Outbuilding / Leisure building.
It is to be constructed of 150mm SIP Panels used on the Floor, Walls & Ceiling.
The SIP Panels are two pieces of 11mm OSB3 Board with 150mm of polyurethane sandwiched in the middle.
My question relates to Ventilation.
When reading guides on creating the best insulated outbuilding it sometimes states that to
be airtight is the best target BUT what about ventilation?
The building will have an internal area of 30 sq/m and there will only be a maximum of 2 or 3 people inside (playing pool / drinking beer) .
I was think of installing two grills that can be closed off if required, like you would have fitted in a standard house, one fitted on either side of the building.
Any advice would be appreciated.
Ron_UK
Ron_UK
