I hope someone can help me. I'm constructing a garden pond. Two actually, with a waterfall between them. The first pond is 8'' deep 30'' long, 36'' wide narrowing down to 17'' wide. At this point it narrows to a 12'' wide channel 8'' deep and 40'' long. Over that 40'' the channel widens to 19'' and ends at a waterfall created by a 19'' wide sandstone block. the water level in the pond will be approximately 1 inch higher than the top of the block allowing water to flow over. The second pond, which is to be lower than the first pond, has not been constructed yet. So the idea is, when the pump stops, the first pond level over the whole area of water will drop by only an inch. That's the theory.
Could you advise what type of pump I need and filter and does the second pond need to have the same volume of water as the first pond. And any other recommendations that would help. Sorry for the lengthy query and I hope you haven't lost the will to live Many thanks. P,S, sorry forgot to mention there will be no fish or plants in the pond. However, there are plants around the pond and lots of small birds, crows and magpies.
