Ok, Had a boiler replacement last year and the electrician made the bolier fuse switch into a plug socket.
Next year I will be installing a water feature in the garden and would like to use this power source as the main feed. I removed the socket and found 1 feed coming in and 1 going out.
What i am proposing is to run a length of cable ( approx 500mm) across from the plug socket to a fused switch which will then run along a further 500mm of the wall and after drilling through the external wall it will come out just behind the drainpipe.
I will then run the cable down the wall, under the footpath and along the fence line to the water feature. As it stands the area of cable run will soon be covered in wall tiles as since the boiler was removed there is some re-tiling to be done.
My question is, Am i ok in using the pond type cable available in most garden centres as the feed from the socket to the fuse and then outside ?
Unsure yet as to wether i will install a single feed to a water feature or run a cable to a double socket which will then feed the water feature and a sapre socket for lawnmowers etc
In terms of Part P and future sale of house, the power supply will be removed and the fuse blanked off if we ever sell.
