I am in the process of designing a garden room and would like some advice as to the correct construction method that I should use.
At the moment I am thinking of a wood frame with 70x50 studs on 500mm centres, this will be filled with rigid foam insulation boards. Outside will be sheeted with 9mm ply, a breathable membrane, tanalised battens then 18mm cedar cladding. Inside 9mm ply sheeting covered with t&g softwood.
The roof will be 200x 50 joists (4m span) on 500 centres, 18mm ply, rigid insulation topped with 3 layers of bitumen felt.
Any advice re the suitability of this construction method / material sizes would be most appreciated.
(size of the finished building will be approx 4metres square.)
