I've been searching everywhere for try and figure out a solution for this problem but I can't quite work it out.
I tore down our old garden shed as it was leaking and rotten. The previous roof was built with the joists resting directly on our garden wall which is made of cinderblock.
I am thinking of putting something back in the space which has a bit better insulation so I can use the shed as an office.
The plan is to build it out of timber with timber frame walls but I cant figure out what is need to do to put it against the block wall. I don't want to overhang the neighbours at all and I'm a bit unsure about damp problems. I should also mention that there is a concrete slab in place running up to the wall which was there from the previous shed.
Do I leave some sort of air gap between the timber and the block with some glittering to drain the water away? How would I finish the exterior if I did this?
Is there some alternative which would allow me to build directly against the block with some sort of flashing/glittering to remove the water?
Any advice would be much appreciated
Rob
Rob
