Garden shredder problems
30 Dec 2008
Bristol
I've got this TRY2100ISD shredder from B&Q (http://reviews.diy.com/2191-en_gb/10787625/reviews.htm). Its been pretty good so far. It jams occasionally. Normally I open it up, clear it, close it and its good to go. This time it won't restart. Any ideas? I've checked the fuse. There is a small black button, not sure what this does but I've pressed it.
Have you checked that it's properly closed? There will be safety interlocks that prevent operation if it isn't.
Yes, Its got a little metal part that drops into a hole when its fully closed. That was a bit full of debris but I've cleaned it out.
Update: It was the the interlock. It seems I hadn't cleaned all the debris out of it. Its got quite an elaborate plastic mechanism that had a bit of twig wedged in it. All working fine now but its too wet to shred
