Evening, I want some garden lights but they are too far away from my socket. Is it acceptable to run one of those garden spikes with 2 sockets on from an outdoor socket?
Not suitable, it is intended for temporary use, not leaving outside permanently.and used all year round
Then run a permanent cable, of the right sort, installed in the right way, (where "right" depends on your particular environment) from there to where you need it.Evening, I want some garden lights but they are too far away from my socket.
What other options do I have please?
You probably could, but you would have to invest in the tools to work with conduit, and learn how to use them. If that level of physical protection is needed then armoured cable would be easier. With either method you would need a suitable weatherproof junction box at each light unless the lights are designed to allow conduit or SWA cable to be terminated directly into them, which is highly unlikely.Could i use that metal tubing and attach it to my garden sleepers above ground?
I wonder how they define "work" when there have been several consecutive 100% overcast days in December or January?The Solar Centre said:A well positioned solar panel will enable this product to work in typical UK winter conditions.
I recall well the problem of 3 electronic transformers for bathroom downlighters which were positioned in the garage by the CU, a run of some 20m of 1mm² T&E each. one seemed fine but the other two only glowed gently..Re extra-low-voltage lighting, take care over what type of supply you use - many electronic transformers have limits on how long the output cable can be.
Oh yes I have 120W of garden lights, 40W is on 2 runs of the stuff that came with them which don't exceed 6m each, the rest is 20m of 10mm² then 80W spread evenly along 20m of 2.5mm². there is a significant difference in brightness.Also (although unlikely these days, I guess) if you use incandescent lighting then long cables will need to be surprisingly thick.
