This is the end result of a swing I've had made.
http://i238.photobucket.com/albums/ff250/Kilnadrain/P1060337.jpg
http://i238.photobucket.com/albums/ff250/Kilnadrain/P1060336.jpg
http://i238.photobucket.com/albums/ff250/Kilnadrain/P1060335.jpg
http://i238.photobucket.com/albums/ff250/Kilnadrain/P1060334.jpg
The posts have metal reinforcement rods stapled to them and are submerged in concrete.
The tops of the vertical poles are dished and the horizontal top pole is attached via three screws each: two 240mm long and one 270mm long.
There is visible movement in the poles when the swings are in use and you can really feel the movement when on them. The poles are securely concreted in and the movement is above-ground only.
Have now put metal strapping over the top pole for added fixing security.
I'm also getting struts put either side of the uprights.
Can anyone give me a definitive answer as to what height the struts should be and how far out from the uprights? Really need to know this so can finally rectify this problem.
