i am in the process of building a garden wall and have read so many conflicting opinions that i would be extremely grateful if anybody could clarify the following :-
there is an existing wall at the moment that takes the topsoil load weight from a small rockery area.
my intention is to build a new wall directly in front of the existing wall (basically to hide the existing)
the proposed new wall will be 600mm (2ft) high and consist of 2 skins (block at the rear and brick on show, this is purely to keep the cost down)
the length is approximately 13metres.
how deep and wide do i need to dig a footing for such a wall
do i need to put any hardcore down before concrete and if so what thickness.
how much (as in sq metre) and of what strength of concrete would i need and again what thickness.
im not entirely sure if i need to make allowances for drainage (i have read plastic pipes could be staggered approx 600mm apart but am not convinced i need that for such a small wall)
many thanks for any advice
