I am about to start a garden wall project and would appreciate some advice and guidance on how to go about this.
I attach below, in terms of what we are intending to do:-
1. A birds eye view plan;
2. Cross-section of the proposed new garden;
Along with:-
3. A cross-section of the existing garden.
Broadly:-
(a) the first wall will be 0.56m in height, holding back 0.41m tall of clay soil behind it (with paying slabs on top of the soil);
(b) the second wall will be 0.71m in height, holding back 0.71m tall of clay soil behind it (with no paving slabs on top of that soil)
For both of the proposed retaining walls:-
1. What width of brick do we need? Can we use single skin brick or do we need double skin? We like this brick here (90mm wide):- http://simplypaving.com/bradstone-p...9_1403979551_fdfa94f3ea894d6fe50ae6c4e38c6135
2. Do either of our retaining walls need reinforced given the height we're proposing? i.e. do we need any type of concrete blocks at the bottom/back of either of the walls?
3. Should we pitch the wall backwards at e.g. 6 degrees or 12 degrees to the vertical, or can the wall be at right angles to the ground?
3. How do we deal with drainage? i.e. do we need weepholes for a wall of this size?
4. What depth of foundations do we need for each wall?
Image 1 - Birds Eye View of Proposed Solution
Image 2 - Cross Section of Proposed Solution
Image 1 - Cross Section of Existing Solution
Along with:-
Broadly:-
