This isn't the gas fitters forum, it's just a thread about it!. You don't see it until Admin has given you access, then it'll appear in the Index. Unfortunately it looks like Admin is taking a while to do that. Email [email protected] and tell him your corgi number or gas-work situation.
Ah, mod's moved it!
Well fwiw I think the best bet at the moment is the Sprint V2, which has more bells and whistles that the V1, though if you're hardly going to use it then the v1 is cheaper. Everyone seems to have the Sprints.
9 out of 10 people coming into "my" ACS centre seem to have them if anything.
I have a Kane 450 which does a low pressure measurements more accurately ( for flues), but otherwise isn't as well done.
the sprint v2 has annoying problems that could be easily sorted with software changes.
mine seems to have no idea whether it is reading positive or negative pressures and will constantly remind you that it is not happy. if you cancel the warning it will flag it up again within 10 seconds, unbelievably frustrating if you are doing something specific like hi-low modulating bp's as the warning obscures everything else on the screen. FFS it only needs to warn you once
the same goes for the low battery warning. mine will work for days with one bar on the battery but it will beep constantly to remind you that you are too busy to charge it. ive almost smashed it into small pieces for this
the magnet on the back is good as is the range of tests it does. battery life is excellent until it gets low and starts whining like a girl.
thanks for all the replys was looking more to the anton sprint v2 kit as i wanted the hole lot in one go just looks like am going to have to dig deep now cheers again for the info
