- Joined
- 13 Sep 2017
- Messages
- 38
- Reaction score
- 7
- Country
I have a 4 burner gas BBQ which is in good condition, but has started acting up. Following removing the burners for a bit of a clean last year, it's not worked as well (possibly wasn't working well before, but has got worse). One burner is unusable as the gas is escaping at the inlet to the burner and burning near the valve. This is the burner furthest from the gas connection. Two other burners have very lazy orange flames (still some blue however). The first burner is blue with orange tips. It has a side burner (the type for a pan) and that also seems to be a lazy orange flame. Seems like overall pressure is an issue.
All burners appear to be in physically good condition (no heavy corrosion) and unblocked. The burners do not have adjustble collars/air valves. They are finned and just slot over the brass valve outlet. I'm sure they are installed correctly.
I have today replaced the regulator and hose "just in case", but I don't think it's much if any better. I'm using a 13kg Flogas butane bottle which still has plenty of gas, but is two years old. I tried "resetting" both old and new regulators by leaving disconnected, closing burner controls, opening bottle valve slowly. No difference.
Suggestions for what to try? thx
