Hi guys hope someone can help me to understand this, even though im studying gas at the moment i unfortunately have a 'part' time teacher- or as it seems anyway!!
Im trying to understand this process so anyone with advice please advise.
My check list goes as follows:
1 boiler loaction
2 locate manufacture instructions and D.C left by installer
3 installed in accordance to M. instructions.
4 check general condition
5 correct flue size and terminal position
6 safe electrical isolation/bonding
7 electrical tests: short circuit, earthing etc.
8 let by test
9 soundness test
10 purge meter
11 correct ventilation
12 check meter standing pressure
13 correct polarity
14 check meter outlet working pressure
15 check burner inlet pressure
16 check min/max burner pressure (if applicable)
17 calculate gas rate and compare with instructions
18 heat input and compare
19 check boiler safety controls
20 locate isolation valve
21 plumbing checks
22 case seal test
23 combustion analysis/ performance
24 explain system operation to customer.
Ok thats it guys, sorry for waisting your time, but does this seem in anyway the order you wou complete the commissioning and is there an vital info that i am missing? Please add info if you know.
1 boiler loaction
8 let by test
9 soundness test
10 purge meter
13 correct polarity
21 plumbing checks
22 case seal test
