Hi all, I'm wondering about electrical power consumption on Gas boilers - both combi and heat-only.
I've seen quite a large variance in ratings, some being only 25W, other 150W.
As far as I can reason, I'm guessing the two main sources of current draw would be the flue fan and the circulating pump, and of those two, most likely the pump would draw the most.
So maybe the lower-rated ones I've seen don't have an integrated pump... I can't recall off-hand.
I ask because I'm on renewable energy so these things are key. Currently, I have a grundfos circulating pump on my solid fuel system that is nearly always on its lowest setting and draws about 7-10W - it's a small system, 3 small single rads and one double, plus an indirect cylinder, open vented, everything is close together with no gravity to overcome as its all on one level.
I'm hoping to add a gas fired boiler to my system so I can set a timer for cold mornings, etc.
The question is, would a boiler with integrated pump also only draw a low Wattage in my system, even though it might be rated at 150W - that being a maximum, rather than a constant? I could be wrong, but I wouldn't expect the flue fan to draw much more than 35W or so... which my batteries/inverter can probably cope with, but if a boiler is going to expect 150W (or more, factoring in start-up draw) on a cold morning, that might be pushing it a bit if my batteries haven't had a good charge the day before.
Appreciate any advice, cheers
