Gas boiler in new home checks?
28 May 2009
Newcastle upon Tyne
This may sound a strange question, but I would like to ask for some advice and information if I may please.
I am moving into my new home tomorrow afternoon, and it has a Gas combi boiler, make is Worcester I believe.
The previous owner has stated that the boiler manual will be left in the kitchen along with other information such as burglar alarm instructions, etc.
Basically, my question is this: If the boiler/system is not filled with water (which I presume it is) i will need to top it up using the key or filling loop, depending what the boiler uses.
But is the gas safe - I will have to turn the gas on myself via the meter (control lever) and i am also not sure about the gas cock under the boiler, I may also have to turn that on.
But as I have never moved before, do I need to do or get anyone to do anything else, to make sure the gas supply/combustion is fully safe, ie the burner pressure/gas rate/check for gas leaks, etc?
Sorry if I sound stupid but I just wanted to make sure and put my mind at rest when I move in.
Thanks for reading my 1st post
All the best.
if your in doubt mate get an rgi in to check it over for you, should be done every year any way
check the bench mark or see if theres any old certificates with it and check the dates on them.
It should be checked every year.
make sure theres no smell of gas.
thats prob about it from a homeowner point of few.
but remember youll not smell carbon monoxide so for your own peace of mind get it checked out by someone
I have a CO detector so that will hopefully put my mind at rest!
The boiler is not really really old, but just as a homeowner I want to feel safe, and have my mind at ease.
It has a flue that goes through the wall (room sealed type i believe)?
So as long as the flue is OK and the boiler case looks Ok then no CO should be able to get into the room/house anyway should it?
Sorry I am probably just annoying you and talking nonsense !
Thanks for your advice.
Have everything checked and tested by a Gas Safe registered engineer.
They will test your gas installation and boiler system for safe operation.
For a local engineer, check here :
http://www.gassaferegister.co.uk/
cant really say with out seeing it, but prob would be fine.
But theres always the exception.
casing seals could be torn/missing under the white cover which you could not see. put your co detector beside your boiler
for the sake of fifty sixty quid get it checked over.
but as you say im sure theres thousands of people that move house every year and dont get the gas applances checked so it entirly up to you
OK that sounds good. After I have settled in, moved everything in and am settled I will find as local RGI and have my boiler (and gas cooker) checked and serviced annually.
For tomorrow will a CO detector near the boiler be safe?
Thanks for all your help
Much appreciated.
i would recomend you get it checked asap
as if ther is anything seriously at fault you can make a claim
think you only get 7-10 days if im right
Apart from checking that the pressure is correct, there is not a whole lot the user can or needs to do.
As it should be serviced anyway, any and all safety issues will show up, and summer is the best time to do such things.
If you know anybody in your area whose judgment you trust, ask them for a recommendation.
If you don't know anyone, a local company is usually better than the ones that operate nationally; you get to know the RGI, and he gets to know you and your boiler.
