Hi, I have a mynute 14se gas boiler who refuses to ignite. Having had 2 leaking isolation valves (on the flow and return lines)which were replaced and lines refilled. The boiler now refuses to ignite. The h20 pressure is above the minimum of .5 bar but less than 1 bar. The flow sensor and switch for the circulating pump remains open. If I assist the sensor/switch and toggle the flow switch the unit fires up and central heating works .But once powered down again the boiler wont light again unless the flow switch is closed. Can anyone tell me what is the cause for this before an engineer callout is required.
