Gas cooker makes noise - suddenly sounds
25 Feb 2009
London
Hi
I recently extend my house and installed New gas cooker in new flat. started using gas cooker and after couple of days while use it makes sudden noise like small burst.
I check all connection and their is no gas smell as well.
Its a suprise , any experence suggestion what could be the reason..
Look forward some one help
Raj
Switch it off & call either British gas or a corgi engineer, not smelling gas is no guarantee that you do not have a leak & without the proper equipment you can tell nothing from physically looking at the connections. Please do not ignore this problem as it is potentially life threatening to not only yourself & any family you have but also your neighboors.ACT NOW!
Thanks for you quick reply
I dont smell any gas odour,offcourse i checked all physical connection with soap water.
I dont believe its leak some technical issue might be...
Might be some expert any help
