Gas cooker -spark igniter stopped working
19 Feb 2006
On my gas cooker hob the electric spark igniter that lights the gas flame has stopped working.
Mains electric connects at base of hob & supplies the igniter.
Any ideas what the problem could be, what typical faults are, that stop the igniter working & what to check ??
How does the igniter feed connect to the electric supply?? Is it a plug/socket or something else???
The first thing is to make absolutely sure there is electricity at that point.
If there is electricity there then you have a problem with the hob. If you dont have a feed there may be a switch or fuse that needs looking at..
There is a socket under oven supplying hob.
I have checked fuse & socket supply, they are ok.
Assuming the fuse in the plug on the hob lead is OK then you've a problem with the hob itself.
You'll need to get someone in who services the make of hob you've got.
