Hi.
My daughter has just bought a house and the electrics are, to say the least, in a mess.
Firstly I want to change the consumer unit for a split load job and then sort out the problems from there.
As far as I can see there is no earth rod to be seen, so will need to get that sorted.
Main query is earthing of gas pipework. Do I just need to run a 10mm cable from the consumer unit to the gas pipework (within 600mm of the meter) or are there other points ?
Do I need to bond the gas/water pipes at the gas boiler.
Any advice will be appreciated.
I am an electrician but spent the last 25 years on factory mainenance so out of touch with current regs.
