Hi everyone
This is my first post and I've had a look for a similar question on the forums, but didn't see anything.
I am getting gas installed in my house and I will be getting the gas combi boiler installed in the roofspace of my semi-detached house. There is suitable space in a couple of cavity walls inside the house to bring the gas supply up into the roofspace and into the boiler, so the piping does not need to be surface mounted on the outside of the house. What is the best practice in regards the routing of the gas feed pipe? Can it go inside the house (in cavity walls) or should it be outside?
My thinking... inside would be the tidy route with all the pipes hidden, but not as safe in regards leaks and harder to get at for maintenance (is there much maintenance needed really?). Outside would be easier got at for maintenance (also for anyone wanting to cause trouble) and, I guess, safer if there was ever a leak.
Thanks for the help in advance.
