Hello.
So now deciding we have to finally bite the bullet and replace our old boiler.
At the moment our old boiler has a 15mm gas feed. Now I know that more modern Combi Boilers need a larger bore feed. I have been told by someone (not that I think he knows) that only a certain part of the feed needs a larger bore up to the boiler and not the whole pipe from the meter. If this is true then great as ours is basically running n through the core of the house! If not then a new feed from the meter to the new boiler needs to be installed. Either way it is what it is. Just would like a heads up on what to expect.
Cheers
Simon
Cheers
Simon
