Hi. My brother has reciently moved house and in the main living room (a through lounge) there is fitted a glass fronted coal effect gas fire.
The fire works fine and it may not be a problem at all, but there is no cowl fitted to the top of the chimney stack.
The chimney stack itself is the type that was built without any chimney pots, so maybe this is why no cowl was fitted.
My question is, is it safe to use the fire as it is or will he need to get a cowl fitted?
Just thought to add this, the chimney is brick built (1930's) and is not using a liner.
Thanks.
pixey
Thanks.
pixey
