Gas fire coals
Could be wrong but I think even the old fashioned white 'tiles' were made of the same material.
Is that kind not made of pumice stone?
Tony
Ok thanks tony
Also when they are cracked in half I understan that the fire gets capped off. But why is this
Adam
Because the flame picture may no longer be correct and could be unsafe!
Where is your tutor?
Tony
Hi
He's sent me off with some questions but couldn't find the answer on Google so I though I would ask someone on here.
So I understand how it's not complete. so does that mean if you done a spillage test it would probably fail
Adam
It could affect spillage but most likely not, but if the coals are damaged and the engineer is not happy with flame picture etc then it is not to manufacturers spec so potentially At Risk by the book and could be turned off
Tony
PMSL. They are ceramic. either "SOFT" OR "HARD".
Broken or misplaced ceramics will often lead to excessive sooting, thence increased CO production.
Moist manf. state that damaged or non standard coals may be used. Therefore, an RGI will feel that applying an AT RISK label, at least, would be justified or demanded.
Don't know about "moist" manufacturers but "most" say that damaged or non oem supplied should NOT be used.
Tony
Tony
Correct. My bad typing/editing. I meant to say that
"...non standard coals may NOT be used",
as was fairly obvious from the context.
