Good Morning,
I have now had old gas fire removed from chimney breast.
The new fire has arrived, it's valor harmony just for the record.
The hole size left after removing the old fire, is somewhat bigger than the new one requires.
Current hole is 650mm wide x 675mm high and 400mm deep.
The required hole is 457-410mm x 565mm x 225mm aprox
My question is I intend to line out the hole using precast concrete slabs, so the sides and the back are lined the slabs will be 100mm thick and jointed using cement mortar.
So is this okay to do and what is best to do with the area below the fire as the fire will not sit on the hearth but be above by about 100mm, the area around the fire will be fire boarded and plaster finished.
I am fitting a hearth, its the void underneath the fire should that also be filled in.
