As you almost certainly have a flue, you could have a "proper" fire!
cheers buddy, by a "proper" fire do you mean a coal fire ?, or am i missing something, LOL.
My missus tells me that the radiators alone arent enough to keep
her warm, she has put up with being cold long enough, she just turns up the the room themostat (in the Hall) to increase the heat in the lounge, but i am sure the radiators should only be a "background" warmth.
So she tells me she will leave the room stat alone and use the fire, if/when i get one.
As regards a Gas Fire, it does seem they are cheaper to run BUT they arent very efficient, with as you chaps point out a lot of the heat goes up the flue.
So because of this Electric looks favourite, i also believe that with a flickering flame to look at she will "feel" it is warmer in the room than it actually is. Plus of course they are far easier to fit !. I like the sound of Easy to fit, not having to get a Gas fitter in to connect it up !.
I can see the exsisting Gas Fire pipe has a Valve on the pipe that sticks out from the brickwork, i assume that to remove the old gas fire (and replacing it with a new electric fire) i wouldnt need to get a Gas fitter to DIS-CONNECT it ????, simply turn the valve off and undo the nut !!!!
tim
