Gas Fire Removed: What to do with flue?
7 Jan 2004
Hi.
We've just had our gas fire in the lounge disconnected by the gas man (for free! ... he was giving our central heating annual check at the time), since we want to take away the fire and gain some wall space.
The fire exhausts through internal flue bricks in the dividing wall between our house and the semi- next door. There's only ever been a gas fire connected.
When boarding up the flue, should we leave ventilation holes, as per a proper chimney?
Yes you should treat the flue as you would if it were a coal fire that you were removing.
you will need to leave a vent into the room - and to do the job properly you should cap the chimney. some even sweep the old chimney first.
the purpose of these precautions is to avoid damp in the closed off void that will eventually cause all sorts of problems. the ventilation is enough to dry the void and the cap is to stop rain etc entering from above.
For what it's worth!
I believe (I'm no expert) that it is important to sweep the chimney first as soot deposists (espicially when damp - no fire to dry out) release an acid which can damage the mortar and brick/blockwork.
I think there have been posts on this forum previously that might be worth searching for.
Just to add on David P post, make sure the cap is ventilated as well for air flow.
thanks masona. yes i did mean to say that but it got lost in translation.
