I have a Brazilla baxi gas fire fitted to an outside wall in one of my hotel bedrooms. The flue for it passes through the wall and vents approximately 400mm under the window (which can be opened).
This fire is not is use and the gas it turned off at the appliance (gas tap).
Annual gas safety checks took place this morning and the fitter has placed a unsafe appliance sticker upon the fire. Because he argues CO can be drawn in the open window from the flue.
I am using a different firm as my usual one is no longer in business
Now this appliance has passed previous numerous gas safety inspections with no problems.
Has the law recently changed I was always under the impression so long as the flue was at least 300mm away from a building opening then it was ok.
Is perhaps the inspecting firm 'trying to rustle up' some business for itself in these difficult times?
In addition there is a gas fire that vents into a chimney in my domestic accommodation that has been condemned due to a 'cracked heat exchanger'.
If I wanted to check this what would I look for?
To be honest this fire is old and I will replace it anyway but I simply want to make sure I am not being spun a line.
Many thanks for an considered replies. They will certainly help my consideration if I use this engineer again.
