Hello
I cannot find the gas related forum, so thought I would post here.
We experienced a problem with the control knob on our gas hob about 4 - 6 weeks ago. I think the control was a bit stuck and did not properly return to the close position, resulting in a small hiss. So we turned off the gas from the main supply to be safe.
Weeks later, we haven't managed to find a suitable replacement hob, so I had a look earlier and thought I'd squirt a bit of WD40 to the problem control to free it up - seems to be ok for now. There isn't anything beneath the panel which the WD40 can affect, can it?
Having had the gas off from the main supply, are there any issues just turning it back on due to the possible build up of pressure? Are there other safety considerations I need to be aware of? Assuming all is ok, can I assume we could continue using the hob as normal without issue?
I'm just wary as dealing with gas appliances usually involves a gas safe engineer? But I am guessing this is only required for the actual connection of a replacement or newly installed gas hob?
Thanks.
Thanks.
