Gas hob electric ignition.
8 Mar 2006
Worcestershire
Wondered if anyone could help me.
I have recently re-done the kitchen and am fitting a seperate electric overn and gas hob (with electric ignition)
I wanted ot know where i would need ot wire the ignition for the hob to ?
I do not have any fused spurs available (being used by the cooker hood) but wondered if it was possible to either wire it directly to the cooker connections spur or the main cooker connection unit ?
Any assistance welcomed.
Ideally it should be onto a fused spur. You can use a plug with suitable fuse and plug it into a socket. It shouldn't be wired to the cooker outlet as that's rated at 30 amps or more.
