Gas hob installation cost
25 May 2005
Southampton
Lots of posts about installing hobs and how I can't use a flex hose which the old cooker was fitted using.
What a fair price for fitting a gas hob from a Corgi person?
Also any ideas on how much to just cap a old gas line to a fire?
___________________________
moderator
please note 9
Any visit £40 + unless it's in the same road as you live (I get a lot of those!). Hob - A few quids worth of bits plus £40 upwards for the hour it might take.
It takes an hour to fit a hob?? :eek: :eek:
I fix my nabours stuff for free plus parts then they don't write to the council about all the boilers and the like dumped outside my house and radiators and the like in the conservatory.
Chris R and I seem to be on a par price wise, he must be in a godforsaken corner where nobody has any money also.
I charge £60 including parts (fittings,pipe,valve) if the gas pipe is below the hob position and the worktop is cut to size. This also includes removing the old hob if replacing, and relighting pilots in boilers (sometimes a real pain). Usually takes an hour and a half, never done it in an hour yet (too much yanking ovens around)
Hmmm, not too sure about that Paul :D
You suggesting it would take much less than an hour Freddie? Even without any woodcutting and using 10mm copper, by the time you found the right bits, checked eveything for operating correctly and gas soundness before and after, got the silly clamps on, or half of them because they don't all fit, it's easily an hour for me.
Did one once in 15mm which was a pain to get at , and had very little space behind/above the oven. Took two and a half hours. Shop was selling me at £80 per hour, so £200, plus vat.
moderator
please note 9
as you can see difference of opinion, it also depends on how "easy" the job is, access to the job, your location etc i suggest you get several quotes then you will know.
On a recent trip to Italy, I noticed that ironmongers (so what else should one visit in Florence?) stock hob connectors which resemble those corrugated copper tap connectors that used to be available here before flexis came in. They were coated in yellow plastic, various lengths (typically 1 metre) and had a 1/2" swivel nut on the hob end, and cost about £12 (probably half that from trade supplier). Connecting hobs with these must be a whole lot quicker and simpler, so why can't we have them here?
Ah appologies i thought you were just connecting a bit of pipe, but then again i didnt know it was your job to cut the hole in the worktop either, something i would never have got in to.
I would definetly charge an hour if not more as it wouldnt be worth it.
Glad i dont do this stuff anymore but i used to love it
