I have recently had my flat rewired and settled in for a few months. Was randomly watching TV and the RCD tripped.
After switching all switches, RCDs and mains off, I turned the mains, and RCDs on and then each plug.
When I turned on the fuse connection unit for the gas hob, the RCD tripped. Its not the oven, that's on a separate RCD and spur socket. Checked it twice.
I called the electrician who wired the place and he tested the FCU and wiring. The copper looked fresh, insulation seemed OK and he replaced the FCU.
We did hear a spark type noise from the hob so he said its best to call Bosch out anyway while I'm under warranty.
Today, the RCD tripped again. It's definitely the hob even if I'm actually not using it. What could it be? The hob is 9 months old, was in storage for 3 months.
Moisture build up from storage/cleaning/spills?
Heating element already?
I was not using the hob when any of these trips happened.
