Folks
I'm planning out a new kitchen extension and trying to start possible layouts. I'd like to install a gas hob and I'm trying to figure out where the gas supply would run.
1. What size feed pipe goes to the gas hob?
2. Can this be teed off from somewhere else or does it have to come from the meter?
3. If 2 is no, I've just had a new boiler put in with a 22mm feed pipe, which runs over the intended hob location at first floor level. Can this be tapped into for the hob or does the boiler need the whole supply?
I'm not doing any of the gas work myself by the way.
Thanks in advance.
Thanks in advance.
