I am looking for someone in the Warwick, Leamington area to inspect my gas installation.
I have two boilers, both Worcester Greenstar, running hot water and central heating in two adjoining properties. I have one gas supply.
The junior boiler is running at 2.5 bar, going up to 3 if I turn it up beyond midway. There is a pipe running from the pressure relief valve which disappears behind the kitchen units so I can't get to the valve. One boiler still has the filling loop connected, is that right?
I can't tell if the other boiler has the filling loop connected or not because all the pipework is behind the kitchen cupboards.
I think an inspection by an independent gas fitter, corgi registered of course, might be a good idea.
Any help or advice will be much appreciated.
