Gas keeps going out
10 Oct 2008
We have Potterton Puma 80 combi and for as long as I can remember if the central heating is on and the hot water is switched on too quite oftem the gas will go out along with the pilot light.
The only way to get the boiler back on is to go through the procedure of starting the pilot light. Sometimes this will happen three or four times a day.
If only the central heating is on the gas never goes out.
Does anyone know why this is happening?
Regards Farmer John
If you mean going out the way I think it to be, It's probably overheating- Possibly because min/max gas pressures are out of range, sensors faulty,pcb not responding to changes in resistances from sensors or blockage...I cant think of anything else, but it is 1.35 in the morning!
Regards
You need to get an RGI to check gas pressures at the boiler, and at the meter.
You need to remove the front cover and watch the red LED on the PCB.
It should come on and off with the tap. If its staying ON after tap is turned off then the flow switch is sticking causing overheat.
Thanks everyone for the advice. I will get the gas pressure checked and also see about the red LED on the control PCB.
As it happened about a year ago I had terrible problems with the boiler which eventually turned out to be several dry/broken joints on the control PCB connectors which was solved quite easily with a soldering iron.
Regards FarmerJohn
