Have had a Anton for about 4 years, gets banged around and still works fine. Very accurate wheel calibration and easy to use.
almost as good as safety matches
Ive had an anglo nordic gas safe 11 for seven years, it can sit there unused for a year or more, plug it into the fag lighter test it and it works.
expensive, but it has a pump, no substitute for a gasco seeker, but very accurate, better than the passive type that have be waved in the gas to detect it which i consider no better than ldf.
last time i used it was during a major underground leak, it found it coming out of grass lamp post and all sort of places
I have an Anglonordic and apart from the poor battery/charger I find the long inlet tube and sucking pump is a real advantage.
Having a sealed battery case is a real pain as it prevents me from replacing the NiCads. Its only a very short time ago when thay finally changed to batteries without a memory effect.
I will probably end up making a seperate battery compartment so that its always available for use.
