gas line above ground?
29 May 2011
Yorkshire
Hi again, whats the best way to route services? Gas and radiator plumbing. Ive been in talks with the plumber and cant decide whether to run gas above or below ground.
My reluctance to bury below ground is i'd have to rip up all the concrete if there was ever a problem. Will it be out the ordinary if i had it routed above ground?
More detail required.
Is this before the meter, after? Between buildings?
Inside/outside? Length of run? Purpose?
The meter is in front garden. Taking a new line in to new kitchen thats located to the side of house. Some of the pipe will be outside.
No problem as long as it is installed/protected as necessary.
