On my new build, the ground floor construction is beam and block with a void below, vented as usual to the outside via air bricks. The Gas meter will be at one side of the house, and at the other side, 20 meters away will be the gas boiler. Whilst I have access to under the house, is it possible within building regs to lay a (say 20mm) yellow MDPE pipe to use for gas. If it is one continuous run, my hope is that the gas Safe installer of the plumbing will be happy to sign it off...I'm aware they could refuse. My question though is does anyone know if this is likely to be OK with building control ?
Thanks!
Thanks!
