We want to replace our boiler and relocate it upstairs. The problem is that different gas fitters are giving us conflicting information.
The easiest routing would be to run gas pipe behind bottom kitchen units and then in a boxed section on the wall. There is a section made of 30 x 30 battens and plywood from the top of the unit to the ceiling. It's about 50cm wide.
One installer told us that by adding extra divider, area can be reduced and gas pipe can be run as this is a duct not a void. Others say that it must be run outside, which would not look nice.
Could you please therefore advise if first option is legally acceptable as I would prefer, but don't want any problems in future.
Thank you
Thank you
