- Joined
- 30 Aug 2008
- Messages
- 223
- Reaction score
- 3
- Country
Hi, we are having a completely new kitchen fitted and we wanted all the pipes hidden in the walls. We want the boiler fitted near the window in a standard kitchen cabinet so it matches and is uniform.
Our gas feed comes out of the back wall in the rear of the property and is fed into the 1st floor room between the joists into the kitchen.
We are having a B&Q kitchen fitted and the designers said that the below cabinet will be able to fit the boiler. Cabinet size 500w x 720h 335d we thought that we would go for the ideal logic + sized at 395w 700h 278d
Now if you look at the template i asked ideal to send me (which they did) - I wanted to ensure that it will actually fit the boiler. But the boiler man i spoke to said the gas pipe must be visible at the wall. We wanted all pipes chased into the wall.
If you see the picture I've measured everything to ensure everything fits. You'll see the black lines which indicate the cabinet height, but at 20mm clearance will the pipes going into the boiler be seen under the cabinet or will they be in the cabinet. It means we'll have to have an ugly pipe boxed in from the top...?
What do I do to ensure everything is flush from the start? Am i missing something? Any Q's let me know. Thanks.
