L
longdogs
hi
just had a boiler service and gas safety check. Everything was fine and our combi is apparently 99% efficient, so all good news.
One thing that did come up was that the gas supply pipe to the boiler (which is in the loft) is undersized. It' currently run in 22mm and should apparently be in 28mm. The run is about 8mtrs from the meter.
My question is: Is this a requirement which has changed in recent years? We had the boiler fitted about 9 years ago, so did the installer install it incorrectly or is it just that the goal posts have moved as usual?
