I had my combi boiler recently serviced and the guy said that the gas was low 12.33mBar. We only have the one gas appliance but he left a warning note to get it sorted.
He said that the pipe to the meter and to the boiler was 22mm so he couldn't understand why but after a further inspection by myself the pipework goes from 22mm to 15mm then at some point back to 22mm when it hits the meter.
Cut a long tail short, it's upstairs in a cubbyhole in the bathroom so the pipe nose dives , reduces on a 90 bend to a 15mm then fires off under the tiled flooring and down out outside but at it stands I don't know which route or were the 15mm starts or finishes.
The problem I've got is the bathroom floor is tiled and boarded out. Is there a cheap inspection camera I can use with a light say that connects to a laptop just so I can drill a small hole and try to find out were the 15mm pipe work is ?.
I can lift a roof tile and thread a new 22mm down the service void but first I need to find out which route the pipework takes and were the 15mm starts and ends.
Once I know were the 15mm is I could do the donkey work and thread new 22mm I've got off a friend along side till leaving access for a fitter so they can couple the new pipework up thus saving a few quid
