Gas price+supply for gas ranger
24 Jan 2006
Cardiff
Bit off topic but can one of u helpful gas bods give me an idea?
Can someone give me an idea on the following questions please. Its about a gas range cooker which has a gas hob and all the ovens are gas.
1. Because its all gas will the supply need to be bigger than 15mm pipe?
2. How much would it cost to disconnect the old gas hob and plumb in this range cooker?
Any help would give me an idea thanks
The cooker is a cannon 10755G and the gas pipe is a straight run of about 5-6m. I need to have a closer look but I'm assuming being an old terace house it is 15mm but could be wrong. If 15mm do you think they could use this on the cooker mentioned or would it need a new bigger pipe?
Look in th MI's. In the tech data panel this should give you the m3/hr for each burner. Add them all up and post back answer ;)
